Hello to all,
I have in test the Burson Soloist, as well as a Swedish amp, Lejonklou Giella PI.
I compared them to my Shiit Magnius and my SP200.
The headphone used is the Final Audio D8000Pro and the DAC a NAD M51.
I'm looking for a more qualitative amp than the Magnius or the SP200, with a less dry sound.
To make it simple and quick, if I had to give a grade on the sound delivered by these amps, it would be like this:
1- Lejonklou Giella PI: 90/100
2- Burson Soloist 3X: 85/100
3- Magnius and SP200: 84,5/100
In fact, I have a hard time telling the difference between each amp (the Magnius and the SP200 are indistinguishable to my ears).
The Jonklou has the best score because its treble is a bit more refined than the others.
The Burson has half a point more than the Magnius and SP200 because if you look hard enough and listen very, very carefully, it has a little more body than the Magnius and SP200.
If I had to give marks on the ratio Performance / Price, it would give this :
1- Magnius: 90/100
2- SP200: 85/100 (it is not a preamp)
3- Burson: 50/100 (about the same performance as the Magnius but 5 x more expensive than it)
4- Lejonklou Giella PI : 20/100 (only one RCA input, no gain control or anything else except the volume)
So, I'm a bit disappointed because reading you, I expected a lot from this Burson...
For me, the conclusion is clear: Manufacturers now know how to make really high quality amps at very low cost and the differences in sound rendering have considerably narrowed. The search for performance is shifting more and more towards the final device: the headphones. I made a big investment when I bought the D8000pro and I don't regret it as it doesn't require 5000 or 10000 € monsters to power it.
Perhabs, if I made the comparison with a Susvara or a HE6SE the result would have been different ? Yes perhabs, but the D8000Pro sounds so good, even with my little Fiio M11Pro.
1- Magnius: 90/100
