Nellie75
Cool. I hear the Burson makes a phenomenal preamp. I hope these adapters do it justice.Mine did that I bought new a year ago
Does the XLR>RCA adapters come with the Soloist 3XP? I saw an unboxing that showed them in there.
Thinking about buying a Soloist ... I'm curious why you did not keep yours ?It does. I just bought one that I did not keep... But adapters were there...
How is the remote for changing the volume?In no particular order:
- The volume knob. It is described as something from way more expensive units and it feels nice but it takes 10-15 360-degree turns to adjust the volume... Extremely annoying. When I am in headphones and I need to turn the volume down I don't want to endlessly spin the knob no matter how nice the knob feels...
- To switch to the line out you have to go through the menu with menu -> rotate -> pre -> rotate -> confirm... My previous amp had a button... Push ones and that's it. It even remembered the volume level for each output... The menu is just not user-friendly... There is a remote control that has a button but I did not try it and it is just too complicated.
- It gets hot. IT GETS HOT! Really hot... I do not need a frying pan on my desk.
- Loud pops. I want to be comfortable when I am paying these crazy prices... I can't believe they could not do something about those pops.
- It is musical and sounds marvelous but the other unit that I was considering was just wider and fuller and hit harder... I preferred the other sound signature. I probably would have loved Soloist if did not hear the other... But thinking about it the low end was slightly metallic... Probably depends on what music you listen to... Soloist is fine, but if you are into Jazz, Electronic, or Rock the other option I had sounded better to me. I actually asked my wife which one she liked more and she certainly preferred the Soloist.
- I was planning to use it with the Burson stand and to my surprise when I turned it 90 degrees the menu did not adjust. I was expecting the menu to turn... Maybe there is a way to do it but I did not find it.
Soloist certainly feels like a high-quality device and sounds good (providing that you like the sound signature)... If you can live with a bunch of really quirky things it is a quality amp. Just wasn't for me. I found it underwhelming and way too quirky. I would take it over any Chinese SMSL/Topping any day but my previously owned Audio GD and Questyle devices were better designed. Burson might be great in visual design but they got a long way to go in terms of usability. If power is what you are after it is very powerful. If you want something to look great on your desk it is beautiful. If you want a user-friendly device that sounds great and pleasure to use there are other things out there to consider...
Anyone have any success running their turntable through the Burson Soloist for HP listening?
I’ve tried running two different ways:
1 - TT into my Sony preamp and then REC OUT (line level, no amplification) to the Burson. This is super quiet.
2- TT into my Sony’s Preamp then out the Preamp Out to the Burson (Sony and Burson are at maximum volume). This is barely loud enough.
Any suggestions?
I am digital 90% of the time. But I would still like to solve this issue with vinyl for the other 10% of my listening.Go digital
I would use a phono preamp. TT to phono preamp into the Burson (or phono preamp into Sony preamp and then out). I'm assuming your Sony does not have a phono preamp built into it.Anyone have any success running their turntable through the Burson Soloist for HP listening?
Any suggestions?
Yes, my Sony has a great Phono Preamp. It works really well. Just doesn't work well when going REC out from the Sony to the RCA input on the Burson Soloist 3XP. This configuration works better going into my Topping A90D, yet is still quieter than I like. I believe the Burson is partially to blame as it is at least 50% quieter in this scenario.I would use a phono preamp. TT to phono preamp into the Burson (or phono preamp into Sony preamp and then out). I'm assuming your Sony does not have a phono preamp built into it.
I think with REC out, tone and volume controls don't work. Pre-outs, they do, but you said you have that maxed out. But other than that I can't help much, sorry. I'm sure someone on here will have a better answer to solve your "issue".Yes, my Sony has a great Phono Preamp. It works really well. Just doesn't work well when going REC out from the Sony to the RCA input on the Burson Soloist 3XP. This configuration works better going into my Topping A90D, yet is still quieter than I like. I believe the Burson is partially to blame as it is at least 50% quieter in this scenario.
My only suspicion is whether the REC out on my Sony is bypassing the phono stage. Normally that is not the case.
