With SS2590s at Input Buffer/ V6 Vivids at Voltage Gain and 994s at Volume Control,
There are faster transients, great resolution in mids (you can hear nuances more now), the upper mids are tamed and the bass is stronger but tighter and not bleeding into mids. With the V6 Vivids at the Voltage Gain, the lower mids/mids are given more air and space retaining a big chunk of the soundstage from stock configuration. Dynamics are improved from stock configuration.
Flip this the other way with the 994s at Input Buffer and SS2590s at Volume Control and you get slightly stronger dynamics, a sort of "3d effect" where the upper mids are pushed a bit more forward and the lower mids/mids are sort of echoing in the back, very noticeable and are present along with the upper mids that are closer to your face. Bass impact is a bit stronger than the Sparkos at Input Buffer. Not as fast sounding as the Sparkos at Input Buffer.
Now there is a third configuration which
@greyforest informed me about the op amps when I did my first chain rolling,
SS22590s at Voltage Gain
V6 Vivids at Volume Control
This is the most dynamic and visceral sounding format. Upper mids are more forward than the other formats, the soundstage is not as wide or deep and everything is in your face. I liked it but on many tracks I found it to be a bit too shouty and intense.
I would prefer the V6 Vivids at Voltage Gain to restore more space and soundstage. So I'm currently using the first format in this post.
