lightoflight
I didn't realize I've missed a couple of configurations in the past posts.
I've added examples 5, 6, and 7 to the document.
Thanks for the link . Any other sound characteristics you can share like bass response and soundstages difference you are hearing compared to the stock op-amps?
depends where you place them.Thanks for the link . Any other sound characteristics you can share like bass response and soundstages difference you are hearing compared to the stock op-amps?
Config #1 has bass for days and is great for headphones that are considered bass light. I like config #2 for its balance and resolution which works better with the headphones I have.Those on the fence about replacing opamps on this amp, I had it stock up until now and wish I swapped them sooner. Running config #1 while I wait for my extenders to try out config #2. Config 1 started out a bit shouty at first but after about 2 days it settled and sounds so much better.
I'm listening this amp for a while. I like Burson house sound. But, It should be listened with a long HP cable in order to staying as away as possible. if you listen open back HP. There is frustrating fan noise. If you listen jazz at low sound level, you can hear fan noise. I'm sure Burson is working on how they can design this amp with passive cooling.
I think it was mentioned somewhere that the amp will not work if the fan is disconnectedhi..you can disconnect the fan, and buy a aluminum block place one under and one of top of the amp
I listen to jazz at low volume too. I have my amp placed below a shelf and it masked the fan noise enough to where I do not hear it.I'm listening this amp for a while. I like Burson house sound. But, It should be listened with a long HP cable in order to staying as away as possible. if you listen open back HP. There is frustrating fan noise. If you listen jazz at low sound level, you can hear fan noise. I'm sure Burson is working on how they can design this amp with passive cooling.
