Same as in playlate, 4 duals.
Burson Conductor 3 Performance & Conductor 3X Performance
- Thread starter escalibur
Mightygrey
I would buy one of these in a heartbeat...if it had an analogue input. I can see a way to play vinyl with it sadly.
cfranchi
- Jan 9, 2016
I encourage you to read the review of the new DAC / amp FCN-10 of Flux Acoustics : a comparison with C3 is done, not to the advantage of the Burson.
https://soundnews.net/amplifiers/he...n-10-review-a-muscle-car-for-your-headphones/
Also take a look at FA-10 amp of Flux Acoustics at Headfonia, better than C3X to drive Susvara (see comments)
https://www.headfonia.com/flux-lab-acoustics-fa-10-review/
cavedave
- Aug 3, 2002
Hello y’all Been listening to my Xp version for 3 days now. What I can say is powerful after 10 or 12 hours turned into a beast. Just amazing.
maszynista1987
My Burson, after 20-25 hours of playing, is amazing! The stage is wide and my leg is tapping to the rhythm of music
Sorry translator
Sorry translator
cavedave
- Aug 3, 2002
You were right the twenty to thirty mark makes a big difference. Made a home made balanced cable for my Senn hd600 using two stock cables pulled them apart braided the four parts together presto changeo new cable with eight conductors instead of four works great with this amp. Running my Beyerdynamic A20 off the dac of the burson and using my T1 with the beyer amp never sounded better.
- Jan 29, 2010
The Conductor 3X Performance, now fully reviewed on Headfonia. We also included a synergy overview with 10 TOTL flagship headphones.
A recommended buy? Find out now in this very comprehensive review: https://www.headfonia.com/burson-conductor-3xp-review/
Enjoy the read
Enjoy the read
Swisshead
yes, Looks very well.... Thank you.
Looking at buying a Conductor 3R or 3P. Would I be short changed on sound quality if I go for a Performance version? I don't need a lot of power as my main audio gear are Sony EIR-Z1R and MDR-Z1R, along with Oppo PM-3 and Fostex THX-00. The price difference between 3R and 3P is $800 AUD. The 3XP is splitting the difference, so maybe go for that one instead? Thoughts?
You probalby wont hear a difference. The changes between P&R are mainly no analogue inputs, and single dac chip in Performance.Looking at buying a Conductor 3R or 3P. Would I be short changed on sound quality if I go for a Performance version?
If you dont need a lot of power it is probably better to get 3P, but afaik there were some problems and Burson have sent 3XP units but not 3P yet. Correct me if I am wrong.
I went with 3XP, want to try balanced output
The 3XP and 3P are available to pre-order with the local representative here down under. I've got the list down to 3P and RME ADI-2 FS then... Decisions decisions... Do I show patriotism and get the burly Aussie or go for German precision and reliability?
Swisshead
In Switzerland you only get the 3R. No other versions, not even the X version and the 3P none at all! A pity. You have to order directly from Burson in Australia.
I'm not sure if I should order one in Australia. Would take the 3XP for my 2nd workstation. We'll see. Actually I have the iFi micro iDSD BL there and I am actually satisfied.
But I would like the XLR connection. I don't really need BT. Think about it again.
Has anyone heard the iDSD BL and the 3P? Are there any bigger audible differences? Is the upgrade worth it?
- Jan 29, 2010
No one has them?
Maybe their X models are on back-order? From what I understand the P-s packaging isn't ready yet, so must be why they don't have those.
Switzerland | K55 GmbH | www.k55.ch | shop@k55.ch | 044 5001100 |
Switzerland | stereotec GmbH | www.shop.stereotec.ch | 044 940 05 46 | |
Switzerland | Müller+Spring AG | www.mueller-spring.ch | brugg@mueller-spring.ch | 056 4422040 |
Switzerland | PortaComp (Distributor) | www.portacomp.ch | mail@portacomp.ch | 055 4515015 |
