userlander
Banned - aka walrus1 - aka vidranger1 - aka iggy-starnuts
- Mar 3, 2009
That's kind of a bogus excuse, imo. If burn in changes the sound as much as some people claim, it would be relatively easy to notice differences. All you would need to do is get two identical model headphones that sound the same (most do), and then burn one in and leave the other one unused. Check them again after X hours of "burn in," and you should have your answer. Even better, do it "double blind," so that when you listen to them, you don't know whether you are listening to the burned-in or the stock version.
One of the strongest arguments against burn-in, imo, is the fact that no one who claims it happens is willing to do that very simple experiment. It could be done very easily with two pairs of cheap headphones or earbuds - easily under $50. If burn-in was as real and caused as dramatic a difference as its proponents claim, it should be relatively easy for most people to hear major differences between the two headphones (or amps, dacs, etc. -- whatever was being "burned in"). I doubt most people would hear any difference at all, or be able to tell which was which from double blind testing.
Originally Posted by jawang /img/forum/go_quote.gif no two headphones (even same model) sound exactly the same, so that comparison won't be valid. |
