HaVoC-28
- Aug 16, 2011
And volume matching is done ?
I remembered seeing stuff like "digital signals don't distort" yada yada. Fact: ODAC is not completely immune to noisy power supplies. I can get hold of more rigs to demonstrate it but I believe the fact that ODAC has poorish PSRR to be pretty conclusive regardless of setup. Something like the Doodlebug would be a great product with the ODAC.
This is at audible level? I guess usb carries lots of noise. Have you tried without AC power? Also, what is doodlebug? Linear-PS?
This http://www.head-fi.org/t/703334/doodlebug-usb-isolator Yes I have tried without AC power and and rigs I'm using have sufficiently clean usb power which measures roughly the same(or a little worse at most) as the below graph. (take note that the graphs are not indicative of the ODAC's true performance as it exceeds the ADC). The signal to noise on rough calculation is approximately -87dbFS which would be pretty audible.
Edit: Tested with my Fujitsu laptop(AC in situation) isolating the ADC side, got pretty clean results with the ODAC. Still got audibly better results as testing was done with monitor disconnected, my monitor is one of those which somehow 'dirties' the USB ground.
