bigshot
All you have to do is define what aspect of the sound you're talking about... frequency response, distortion, volume/gain, timing. It would help if it was measured to verify your impressions too.
Doing a controlled listening test with two sets of speakers isn't hard. Just set them side by side and blindfold the listener and tester. Make sure the distance is far enough that the space between the pairs isn't discernible, or do multiple tests randomly swapping them back and forth.
If something can't be measured, it can't be heard. Our ability to measure sound FAR exceeds our ability to hear it on every aspect of sound reproduction.
