Killcomic
Oh, those dastardly cads! Taking advantage of our biology and such!...and they want you to get used to it so you won't realize it really isn't what you want and return it!
CONSPIRACY!
Sure, they want you to get used to the sig as it may sound better, but there other facets to this. Audiophiles can have the wow period when they initially get new stuff as well, and as they used to it, sound becomes meh or bored of it due to not getting that high as you are used to it....and they want you to get used to it so you won't realize it really isn't what you want and return it!
I wouldn't say make myself like something. I try to listen attentively for faults(or weak aspects) as that's most useful info. This is partially the reason why I need to give things a bit of time to form an opinion.Let us not forget also that people don't like wasting money and you will subconsciously make yourself like something.
I guess that's why you never hear anyone say "After 8 hours of pink noise everything sounded horrible"
But how would you know if you're doing it subconsciously?I wouldn't say make myself like something.
@jagwap : Do the manufacturers of said speakers provide information that says they will audibly change over time to the expected level of tuning?
Of course they do. They don't want you to return it right away and put the suggestion in your head that it will sound better if you stick to it.Most of them (from memory) do. The manual will mention they may benefit from being played for a day or two. The retailer will also suggest this.
Edit: http://www.klipsch.com/blog/how-and-why-to-break-in-your-new-speakers
However I have heard break-in between examples of the same speaker. I have heard it repeatedly, sighted, blind and double blind.
Tell us about how you conducted your double blind test of speaker burn in. I'm interesting how you would set up a test like that to account for all the variables.
That's a sighted test, and the ABX switcher would be pointless.It is difficult... I didn't conduct them but took part. I did the electronics blind testing, which is easier to achieve.
One company: Using an ABX switching box to change between the samples, which are set up next to each other. The test is repeated with the positions swapped to null the spacial aspects.
Echoic qualitative auditory memory is less than a second long with peak ability to discern small differences occurring with no switching gap, and decreasing radically with increased gap time. The more similar the samples, the less gap time is required to reduce comparison ability to zero.Another: leaving the room while an assistant swaps or doesn't swap the samples. This needs longer accoustic memory, but removes the spacial cues.
This was also done on occasion with supposedly transparent material in front of the units, with less success. The conclusion was the acoustically transparent material was not transparent enough when units sounded quite close.
What was being compared? New drivers to broken-in ones? New to other new? Regardless, the long switch time would invalidate the comparison.However it is easy to hear when the drivers are new. After break-in it gets harder not to imagine a difference so that is when ABX helps confirm the pre-production units.
Unless the material in front of the units affected the samples unequally, or imposed a radical response modification that changed with frequency (and should never have been presumed acoustically transparent in the first place), the delta between samples was not affected by the material, and would still be apparent. But the long switch time would invalidate the test anyway.
In no case in the above description was there an actual ABX/DBT, the test protocol design seems quite amateur.
