Gerxld
- Aug 11, 2010
thanks for the heads up!
Tube won't matter that much with this amp unmodified. You should first make it better by at least changing the output FETs for better treble, the old FETs rolled the frequency at 10KHz.
That's not true. My amp isn't modified and a better quality tube than the 6N11 make a noticeable difference. Just because the frequency is rolled off at 10kHz doesn't mean a tube cannot improve the sound and change a bit of the sound signature. I would recommend changing the tube first as it's a cheap and easy to replace item on the amp. So what if it rolls off at 10kHz not everyone can hear to 20kHz anyway.
I didn't say it won't matter at all. It will of course make a different but not worth the money. A good 6N11 in my country will cost me 30-40 euro, same price as the amp.
Ok, so I just got my amp and I'm going to break it in in just a few minutes.. I do wonder if I got my tube inserted the correct way, It seems very loose, I'd guess half an inch of the "pins" are showing above the tube socket and some of the pics I've seen on the eBay listing has them almost level to the socket. Is that how they should be?
Because they take quite alot force to get down lower than this.
Cheers
The tube bottom should be at the tube socket. The pins should not be above the socket. The tube has nine pins with a larger space between pins 1 and 9, which matches up with the same space on the socket. If you have the pins in the holes and it lined up as I mentioned, you should be able to push the tube into place. Do you have an image?
