I finally finished my small review of the BQEYZ Autumn. One of the biggest surprises of 2021 for me for sure, and one of the best single-DDs I have yet heard! BQEYZ Autumn
The Oxygen have better clarity, imaging, instrument separation, micro-details, and air.
The Autumn, however, have a bigger soundstage and thicker note weight, with the Oxygen sounding a bit thin in note definition.
The Oxygen do not have any tuning options, and can sound a bit bass light for bass forward music genres, so the Autumn have the edge in terms of versatility, as it can be tuned bassy to U shaped to neutral with the magnetic swappable filters.
The Oxygen may also have fit issues due to their shorter nozzle, and they also weigh in at a substantially higher price than the Autumn.
Hmmm... As the 2021 Hana is, from others' reports, a baby Oxygen and then the price of the 2021 Hana is in line with the Autumn.... If BQEYZ would kindly lend me an Autumn, I would gladly compare the 2021 Hana and the Autumn.
To bring up a broader point, I think it would be in manufacturers' interests to lend units outside of the exclusive "reviewers' club" here at Head-fi. I think we plebeians deserve a sponsored voice from time-to-time.
You need to become integrated more. Meaning your asking for an IEM to review but you only have one review? I can’t tell what the review is as your profile is blocked. So how is a company to make a decision about a reviewer when they have a single “unknown” review posted? I hope this comment doesn’t come off as criticism or in the wrong way? I’m simply trying to help.
I bet if you wanted to you could write 7 reviews of stuff you own!
I was sloppy with my wording. I was talking in general that manufacturers should lend units for lesser known members here, not necessarily myself alone, for auditions and impressions not necessarily full reviews. I don’t have the spare time to do a full review. There are many insightful members here. I think more voices could help those that have to buy “blind” make purchases with less regrets.
I picked the Autumn as it could be an IEM that might suit my tastes but that treble peak makes me wary. But, I cannot audition the Autumn so how would I know?
The BQEYZ Autumn are a very underrated midFI single DD set.
The magnetic swappable concept for changing filters is very innovative and allows swapping of filters in just a matter of seconds. This gives less wear and tear than traditional screw on nozzle type filters. Sometimes it is such a hassle to change nozzles on other IEMs that have a tunable filter, that one just leaves on a default filter and calls it a day, which isn't the case with the Autumn.
Graph of BEQYZ Autumn via IEC711 compliant coupler. 8 kHz is a coupler resonance artefact.
The tuning filters here work, and ain't gimmicks, cough cough looking at you BGVP DMG! While the filters appear to only affect the bass region, the ears perceive the entire frequency spectrum as a whole, so changes in the bass will cause a "see saw" effect on the treble region and vice versa.
The grey filters (AKA bassy filters) give a V-shaped sound signature. Bass is just a level shy of bona fide basshead levels.
The gold filters (AKA balanced) are the default filters, and provide a U-shaped balanced sound, as per its namesake and is my favorite configuration. The most-all rounder.
The silver filters (AKA treble filters) give a cold neutral tuning with added clarity and micro-details with a neutral bass.
Micro-details are above average, though there might be some multi BA/hybrid competitors with better resolution. Soundstage on the BQEYZ Autumn is excellent, with good height and width. This aids instrument separation with no congestion noted even on busy tracks. Imaging is decent but not class-leading.
The Autumn have good instrumental timbre, and are quite solid in build.
Some nitpicks are: the Autumn has an occasional glare at the 5 kHz region though, and scales better with amping. Isolation is also below average.
Compared to some midFI single DD luminaries, the Tanchjim Oxygen have better technicalities and resolution, but is more expensive and has a poorer fit (too short nozzles). Note weight is also thinner on the Oxygen. The Autumn are slightly better than the Moondrop KATO in terms of technicalities, and the 3 tuning options give more versatility than the 2 screw on nozzle configs on the KATO (which are very subtle changes in sound signature).
All in all, more folks should try the Autumn, they are very versatile. Trebleheads to bassheads should find something to like about them, and the innovative magnetic swapping tool to change filters is really quite ground breaking.
