Hello,
I want to replace my plantronics backbeat pro and I'm hesitating between 2 headphones. Either the B&W PX or the B&O H6. I will use them only in the library, street, bus (not at home as I have a K712) so noise isolation is pretty important. I found a very good deal for the B&O H6 (new for only 169 £) and I can use them with my s7 and e17k, however it does not have active noise cancelling and bluetooth is quite convenient I must say. What do you think is the best deal in my case?
Thanks
PS: I listen to classical/rock, I have glasses and comfort is really important
The isolation with the PX are excellent. In quiet environments like the library, you don't even need it. The bus maybe, but the street, if you have it loud enough, you don't hear anything around you. If you must have ANC then you can activate the OFFICE mode and that will work great. If you can afford the PX, I recommend them. I use mine on the subway, street and home. I only activate the ANC when I am on subway.
