Bowers & Wilkins Pi8 and Pi6 True Wireless Earbuds
Oct 9, 2024 at 1:11 PM Post #182 of 327
Why are people recommending the Comply TW-170-A for this TWS?
They absolutely do NOT fit. The nozzle of the Pi8 is too small for them.
$24 wasted based on recommendations by this community feels bad, man.
as you can see not only users but even comply suggest TW-170A for pi8
Oct 9, 2024 at 3:51 PM Post #187 of 327
sorry but i am totally confused, as you can see in the screenshot in my previous post they recommend these tips for pi8. So are they compatible or not?
They suck for the Pi8. Look elsewhere, IMO.
Oct 9, 2024 at 3:56 PM Post #188 of 327
They are compatible. The „manual“ on the package says that you have to push them firmly “past the initial resistance until the inner core is flush with the earphone”. So, they fit as intended. That does not mean that they “enhance the audio”. The design is called “True Grip” and most likely that is meant that these tips “stay in-ear-fit”. The connection is designed that they won’t stay in the ears, when you pull the earphone out. In that sense, they work well, but in my experience not in terms of comfort and sound quality improvement (which the Pi8 actually does not need).
Oct 9, 2024 at 4:04 PM Post #189 of 327
But the way the tips fit makes them LESS likely to stay in your ear because I makes the tips too short.
Horrible design all the way around.
Oct 9, 2024 at 4:43 PM Post #190 of 327
They can be fitted if you jam them on but don't fit in such a way as to be of much use.
There is clearly a mixup at Comply.
Not unheard of for such a thing to happen.
I didn't even open the pack I bought as I could tell they weren't going to work by looking at them and comparing them to the OE tips. The central 'barrel' is too short.
Could one of you guys who actually got them onto a Pi8 upload an image please to demonstrate?
Oct 9, 2024 at 5:01 PM Post #191 of 327
I don’t think so. The resistance to put them on is so strong that you would never leave the ear tips in the ear, when you pull the PI8 out. I had tried some ear tips, I have from other ear phones, including Comply TX-200 and TX-500. They fitted much easier on the nozzle, but all of them too easily stayed in the ear, when I pulled the Pi8 out. So the issue is real, and from that point the TW-170-A are really, really safe.
Oct 9, 2024 at 5:25 PM Post #192 of 327
Oh, that’s largely because they won’t grip your ear canal at all or form a seal.
So, yeah, I mean… they solve the problem by not being functional enough to be able to even get snug within your ear canal.
I’d say that’s kind of a “late stage capitalism” approach to a solution.
Oct 9, 2024 at 6:02 PM Post #193 of 327
Before I sent back my pi8, I tried regular sized Azla crystals and regular sized spiral dots. They both sort of fit, but will come off in your ear and make them sound bad. I also tried the azla crystals for tws and while these snapped on nicely and stayed, they sit too short and sound awful like the others. Kind like they weren’t getting a good enough seal.
Oct 10, 2024 at 1:22 AM Post #194 of 327
i found awful sound with azla smr standard and pi8, great fit rubbish sound, stay with originals.
