These arrived at the Apple Store yesterday so I picked up a pair. The portrayal of dynamics is really something.
Yep...got mine today as well. So far, so good. Very impressive headphones.
Thanks for the heads up yesterday Dave!
Are you using the P7 amped? If not what are you using for the source?
Right off the bat, the sound improves just from not being filtered through rubber/fake leather, or whatever material the P3 and P5 use to cover the drivers. Now there is just a thin layer of cloth.
If I could use an analogy, I find the change (from the P3 and P5) similar to when Grado introduced the bowl pads which replaced the flat pads. The bass got tighter and the soundstage opened up. The big difference is that, unlike the Grados, the top end remains warm and clean, and lacks any sort of sibilance and brightness problems. What I am finding with the P7 is the bass is present for sure, but in a good way...kick drums kick, electric bass throbs, things residing in that range have power and dynamics. And unlike the Momentum, for example, the P7 is alive and kicking in the midrange as well. It's like a Sony MDR-1R with some good kick and presence in the bottom. But with much better midrange accuracy and timbre.
I think they sound better than the B&W P5 and the Sennheiser Momentus, so B&W did a great job regarding sound quality. However I feel it's below the sound quality of IEM in similar price range. These headphones are not comfortable at all also.
I don't think these will replace my IEM.
I used the Momentums during a 8 hour flight. Couldn't take them more than a couple hours at a time. Because they touch my ears slightly they gradually became more and more irritated. The P7 don't touch my ears at all, so I think they'd do much better. The headband padding is a bit thin, but it hasn't been a problem for me during longer sessions so far.
I find the earpads and clamping force on the P7s to be quite good. The problem for me is the rather small and firm headband, which distributes the weight of the headphones over a small area. I much prefer the headband of the Momentums. Unfortunately, the earpads of the Momentums are too small. So I'm still searching for the perferct combination of sound quality, isolation, comfort and looks. Maybe the AKG 545 will meet all requirements?!
