Nebby
- Aug 31, 2004
You can also find a piece of small metal pole that has the same diameter as the pin, cut it to length and use that to guide the jig down properly.
Originally Posted by Nebby /img/forum/go_quote.gif You can also find a piece of small metal pole that has the same diameter as the pin, cut it to length and use that to guide the jig down properly. |
Originally Posted by Nebby /img/forum/go_quote.gif Have you already picked up the parts from parts-express? Parts-Express.com:*Mills 4 Ohm 12W Non-Inductive Resistor Parts-Express.com:*Dayton DNR-4.0 4 Ohm 10W Precision Audio Grade Resistor |
Originally Posted by Nebby /img/forum/go_quote.gif For my speakers I plan on veneering sides and back with a satin finish on front. Doing the same for my SR-71's. Amazingly enough I found a 36mm bit at the 100 yen store, so I'm set to start work on the ZBM4's. |
Originally Posted by ThePredator /img/forum/go_quote.gif Parts-express definitely lives up to their name, I got my order from them the second day after ordering. The speakon plugs are a bit larger than I expected, but they should still work (and they are built solidly like all other neutrik gear). Once my madisound order comes in I can go ahead and build the crossovers (might be a couple days before I can get back to wood working). When building the crossovers, is there any steps I need to take to minimize parasitic induction, or should it be a non-issue? |
