ThePredator
- Jan 25, 2009
Should I just grab a normal one (what I currently use, not sure what brand) or does MDF prefer a down shear or spiral (or any of the tons of others I can't remember)?
Also, on the port, can I just use some PVC, or does the flare actually do something? Unfortunately ordering one would cost more in shipping than the actual part (I would have to grab it from Parts Express because no one else has a 1").
Then I will probably go with the speakons, I do love Neutrik gear and I can't say no to just how damn professional the plugs are/look.
[EDIT]: What is a good gauge for speaker wire and is there anyone who sells that gauge in a sleeved two wire form (not very particular about cables, just has to be copper)?
Originally Posted by cyberspyder /img/forum/go_quote.gif Do you have a flush trim bit on your router? Better buy a spare, as it is going to get dull quick. |
Originally Posted by Nebby /img/forum/go_quote.gif The speakon plugs/jacks are typical neutrik...fairly easy and simple to solder. If your side panels are properly cut, using a straight cut bit with the router leads to perfectly sized tops and bottoms |
