By his IG feed it appears that he has been happily tweaking Aiwa ear buds/drivers; re-tuning Vidos; and cable modding/experimenting with his MX & PK (32 > 150Ω) lines.
Blur Earbuds Lovers
dh0licious
What's the best way to get in touch with Wong? Does he have a website where he lists his stock, or only does custom?
gazzington
prionsarebad
I have made contact with Wong. He sent pics if several models. I asked which model is warm/dark. He said the Aiwa drivers and the MX.
Any advice please?
Also 32vs300ohm..... thanks!
Any advice please?
Wong is well known for giving very solid recommendations so whatever he recommends is most likely a safe bet. Also, he does individually tune by request so carefully explain what tuning you desire; your preferred music genre; and your typical listening level.I have made contact with Wong. He sent pics if several models. I asked which model is warm/dark. He said the Aiwa drivers and the MX.
Any advice please?
Regarding impedance... that is a tougher one to offer sound advice but 32 Ohms will work better with smartphones and sources without the need and/or use of a HeadAMP or DAC-AMP combo whereas higher impedance earbuds like 300 ohms will scale better with a dedicated DAC/AMP.
prionsarebad
Sorry, I should have said I have a collection of amps, but only my Atom will drive 300ohm easily....my question was more along the lines of does the improved sound/performance of the 300ohm when properly powered justify the limitation of only being able to listen to it via the Atom? Thanks.Wong is well known for giving very solid recommendations so whatever he recommends is most likely a safe bet. Also, he does individually tune by request so carefully explain what tuning you desire; your preferred music genre; and your typical listening level.
DBaldock9
I've driven my 300Ω Blur, 320Ω VE Zen, 500Ω K's 500, & 600Ω K's 600 with various devices that are rated from less than 100mW, to over 1W per channel.
I think they sound good, whether I'm using a lower powered, or a higher powered, DAP/DAC/Amp.
Saoshyant
Well, my pair of Blur seem to be having an issue at the jack. Shame as they have relatively low hours.
Sorry to hear that! I spoke too soon Send back to Wong he will kindly repair for you without question.Well, my pair of Blur seem to be having an issue at the jack. Shame as they have relatively low hours.
My Blur 美魔女 Beautiful Witch "Dark" (300Ω) ear buds being driven by a XDuoo XD-05 Plus Black Edition HeadAMP:
prionsarebad
I have made my first order with Wong for the 300 Blur
Looking forward to being a part of this exclusive club
Looking forward to seeing what version he sends you!I have made my first order with Wong for the 300 Blur
prionsarebad
He said it was this one...
Ah okay, the Blur 300ohm OFC... I believe he nicknamed this earbud model <<Henna Gaijin>> "Strange Foreigner"
