Luke Thomas
Refurbished node 2i. $465. Might be a thought as I bought refurbished Sony headphones that were perfect.
Product ordered. I have 2 amps to juggle. Marantz with floor speakers. And Violectric with my Sennheiser 800s headphonesDefinitely a super nice all in one solution even at the full price.
Just saw one used here in the for sale section for much less than the price you mentioned.
Be aware there is no headphone jack on the node 2i. You'll need a headphone amp or an integrated amp with a headphone jack. The latter is not a good solution for many headphones though.
So I got the 2i. Set It up to work with WiFi.
the level of detail is unlike anything I’ve heard. I wish it had more bass.
Oh sorry thanks. Do u know of anyway to enhance bass? This is always a big issue with headphone rigs. To get detail. The bass has to be sacrificedYou're welcome
Not sure which are fixed. My only option was the rca cables out. Fed to my ampAre you using fixed output level from the node 2i? Seems to me the bluesound control panel has tone controls but I don't use them.
I just have the node turned all the way up. Then use my amp to adjust. The manual is not good.I mean there is a fixed volume setting on the node 2i, I would recommend using it. Drive the headamp fully and control the volume from it rather than the node 2i.
Thx for your timeYes! We have no manual. The controller app is pretty good and the updates are amazingly trouble free.
Thx for your time
