Slater
Is the Blon a Para B then?
No, Blon is NX7 style. TFZ has a few models that also use the same socket.
The ABC is a KZ thing. Blon uses different sockets.
One thing I find fascinating with this IEM is that there are like 10 or so graphs and every single one of them is completely different from the next. Like its a totally different IEM type difference. Never seen that before with any other IEM. Usually they are all really really close with very small variances. The Blon 03 is all over the map.
I dont know, after I changed the cable it's like I switched from $5 flea market set to a decent $100-200 set.
Just got my 2nd bl03 and I stupidly ordered the same "gunmetal" color as my 1st one lol.
oh dear , can you still contact the seller to correct the order?
Nope, it has been delivered to my house. I already ordered the silver one. I could return the 2nd gunmetal one if I want to (thank God I ordered thru amazon).
Given the difficulty of getting a proper fit for a lot of people, my guess is the differences we see in FR graphs is due to:
1.) getting a good seal with the coupler
2.) getting a reliably consistent insertion depth
3.) making sure the vent by the nozzle isn’t blocked by whatever is being used to seal against the coupler (usually blue tac)
4.) the source used for the measurements (cell phone or laptop vs an amplified source).
Ok, I could find 9 FR graphs:
full: https://cdn.head-fi.org/a/10367523.jpg
As Slater pointed out, rig variation, insertion depth, seal, etc... will play a role. But apart from the last ones I don't think they stand out that much from each other. The Crinacle's unit isn't flat at 400Hz but you can see Antdroid's FR graph only one side gets flat at 400Hz, which could be a just filter position mismatch. At least my gun-metal pair is highly addictive.
Actually forgive me for asking a noob question as I don't own any measuring gear, but for the BLON, can we even compare and draw conclusions from different graphs from different users with different equipment? I'm curious about this question.
I always thought that one should compare the IEMs (say brown and silver BLON) using the same standardized equipment to be fair.
I bought a P1, then a Fiio Q1mk2 to use with it, I was happy. Now I have a Ikko OH10(which I liked a lot), ordered a Shuoer Tape(not here yet) and I'm thinking of buying this one because is inexpensive. But based on what people are saying, maybe I should just have bought this one instead of making a chifi colection... :O
