dre145
- Apr 14, 2014
some thoughts on the bl-01 vs bl-03 (at least the tuning i got):
Bass definitely cleaner and not bleeding into the mids.Treble as a whole is good, but prefer the one on the 03. Instruments are pretty decent on the 01 and are slightly better than on the 03, stage on the 01 slighty more expansive > than 03. Overall the 01 is less musical to my ears than the 03, but is way more polished than the 03 in stock config. The ideal set may have been a combination of both??
For reference, I did the filter mod on the 03, which already cleaned up alot of the bloat. 01 is fresh from the box. I used the same cable and sources. The connector seems to be 0.75..had a very tight fit using 0.78 to the point where i felt the pins could snap if i forced in it more...
Thank you appreciate your insight, waiting for mine to come was supposed to be delivered today but still not here hopefully by friday. Ordered a few 0.78 cables since I thought thats what the connection is. Will have to slightly bend and force them in.
