Blon in ear monitors impressions thread
Oct 30, 2020 at 10:58 PM Post #4,217 of 6,129
I don't have a suitable cable at the moment, the one ordered is yet to arrive. I was using them with the stock cable.
Before it had started working again anyway, after half an hour he died again. :sweat:
I meant - take the cable out of the working one and plug it into the non working one - if it syarts working it is your cable that is borked and your IEMs are fine. Still mighty annoying.
Oct 31, 2020 at 9:05 AM Post #4,221 of 6,129
I adapted a KZ cable by cutting the protective sheath and releasing the 2 pins, it works perfectly. Provisional solution pending the ordered cable which should arrive between Monday and Tuesday.
I also cut the sheath that forms the headband and now the cable no longer tends to pull the iems out of the ears but is stable.
Oct 31, 2020 at 9:08 AM Post #4,222 of 6,129
I don't have it at home and neither does Hosa Deoxit. Is it possible to use anything else?
not sure, sorry :frowning2:
I’ve only ever used Deoxit Hold for years. One can will pretty much last your entire life, so it’s a no brainer.
Oct 31, 2020 at 4:35 PM Post #4,223 of 6,129
I got the perfect seal with about 2 mm o-ring at the base - actually I just cut out a small piece of a KZ starline M too small for my ears - and KZ starline flip tips size L. This way I also get a perfect isolation.
Nov 1, 2020 at 1:02 AM Post #4,224 of 6,129
So I don't have the proper cotton sheet...
So I used toilet paper in the meantime. As far as I can tell is sounding less upper mid/treble forward with this paper while air restriction is insignificant.
Although I imagine this is only a substitute until I can buy the real thing.
Edit: Should this filter be as tall as the nozzle itself? I think I made mine 1mm short of covering the entire nozzle height.
Nov 2, 2020 at 8:07 AM Post #4,225 of 6,129
So when is the new blon coming out?
Nov 5, 2020 at 3:21 AM Post #4,228 of 6,129
It's up now on Linsoul (link). $19.99
10mm Biology Diaphragm Driver
Continuing the legends of BLON families, we have made it to BL-01 with the new biology fiber diaphragm driver, which can fully reduce the strong human voice drum point of mid-low frequency, restore a shocking low frequency sound effect, making the sound more layered and allowing you to clearly feel instrument sounds and vocals. You can fully enjoy a magnetic bass experience.
I'm not familiar with this driver description but I hope it has some BL-03 analogue magic as well. For $20 and possibly some discounts on 11.11 w/ AE coupons it seems a good blind buy.
Nov 5, 2020 at 3:33 AM Post #4,229 of 6,129
Just ordered some. Can't wait to enjoy a magnetic bass experience, though arguably all my bass experiences have been magnetic... and that's me for chi fi until all my sets break again, hopefully with the six sets i've bought in the last two months that will be a ways off.
Unless someone else releases another mother of all bang for buck giant of giant killers... So next purchase in a fortnight then.
Nov 5, 2020 at 3:37 AM Post #4,230 of 6,129
Ordered mine and the tape pro.
