tgx78
Member of the Trade: tgxear
Still loving mine (bl-03) with pure silver cable and the e1da s9038. I EQed down little bit of mid bass and bumped up 5khz slightly to emphasize stringed instruments and find it so enjoyable.
I think I mentioned this before but mine spikes at 5kHz and 10kHz again if i remove the mesh and don't use my Dekoni Bulletz.Still loving mine (bl-03) with pure silver cable and the e1da s9038. I EQed down little bit of mid bass and bumped up 5khz slightly to emphasize stringed instruments and find it so enjoyable.
Wow, that looks similar to the Starfield color
They could have made de nozle slightly longer.
I actually ordered those, however I think the thicker 16core cable will most likely be too big to fit inside.
I would try the mesh mod that slater told us about. Changing tips to a wide bore tip like the azla or jvc spiral dots might work too. Otherwise If you use EQ correctly and with a good EQ (like the one in the Neutron player) it shouldnt affect the sound much if all you need is reduced bass quantity.Anyone know how to reduce the bass quantity and decay on 03? I don't like to do some eq stuff, it messed the detail and I feel like something is missing on a song. Did burn in process will make something different? It's my 2nd time owning a blon 03 and Its still the same sounding iem's.
Because I already love the natural timbre on this iem's just as final e5000 that I sold to upgrade my main iem..
Sorry my bad English
If you have a good PEQ, low shelf cut will be still the best option.
You could also block this tiny vent by the cable connector to see if reduced air flow might change the bass quantity.
