JEHL
That sounds like the opposite of what I want, I want less V shaped, not more.In comparing listening to the BL03 with Sedna Light Short tips vs Sedna Xelastec tips, I previously stated that...
“It depends on what you want. Sound wise, it makes the treble brighter and airier. It sounds slightly more dynamic, lively, and V-shaped. It doesn’t really make the mids sound more recessed though, it just accentuates the treble especially, but not the upper mids that I can tell. To me, the bass doesn’t seem more in quantity, just a little punchier, and perhaps slightly cleaner.
Edit: I guess take my sonic impressions with a grain of salt, as they seem to differ from other peoples experiences. ”
Since then, I read other‘s opinions that the Xelastec actually tames treble peaks, so I listened further, with different IEMs. Well, I still come to the same general conclusions, but I think I have a plausible explanation. I think the material used for the Xelastec, to me, causes more reverberations as a whole. I notice it most in the bass and treble. The bass seeming more “punchy“ is likely due to more mid bass reverb, and the sound is a bit warmer as a whole. The treble also has more reverb, and is more “wet” sounding. One track where I notice it a lot is Panic! At The Disco’s High Hopes. The overall effect is a brighter sound.
Edit: Also contrary to my worst fear, rather than boosting all the treble overall, the mesh removal appear to simply make the treble roll off slower than if it had it on. Does that sound beneficial to all of you?
Edit 2: Also if it's not clear already, I'm neither a basshead nor a treblehead. Probably not a midhead either if that's a thing.
