You can literally poke a tiny pinhole in the stock BL03 with a very small size of sewing needle and get that right now
True but people are not brave
Wow, are they trying to be kz 2.0?No. The 03 pro is a new one in the works.
I had same problem , small size package took about 1 month and 5 days to move , but had big package move in a week
Did you measure the impedance before returning?Just as I was getting adjusted to the Blon 05 sound signature using foam tips and really starting to enjoy them I noticed that the volume on the right earpiece was much lower to the extreme. I returned them to Amazon with no issue at all and recieved a refund.. I may repurchase them in the future if the price goes lower than the 50 bucks I paid originally... Different from 03 but has its own pluses... Still loving the 03..
How are people enjoying the BL05 with foam tips? I'd imagine that helps with making the bass a little more tasteful and softening up some of the other peaks?
I’ve had three sets of phones do this and in every instance there was a polymer mesh under the metal mesh that caused the problem. I removed the polymer mesh and the problem disappeared. Attached is a photo of my TRN V 90 showing the polymer mesh being removed. I leave my phones in overnight and one or both sides would go quiet by morning, then recover for the beginning of the next evening’s listening. Not any more. The V90 mids came forward some, so it might change the sound for others as well. One set of Bluetooth phones had only polymer mesh so I’m going without protection on them, but they used to go completely quiet on both sides until I removed the mesh, now no problem.Just as I was getting adjusted to the Blon 05 sound signature using foam tips and really starting to enjoy them I noticed that the volume on the right earpiece was much lower to the extreme. I returned them to Amazon with no issue at all and recieved a refund.. I may repurchase them in the future if the price goes lower than the 50 bucks I paid originally... Different from 03 but has its own pluses... Still loving the 03..
There are reports on Facebook with graphs showing that putting a 2.5mm square of 3m micropore medical tape on wax guard of the 05 produces the results you describe.I'm interested in seeing the reverse as well, like what would happen if you combined the BL05's bass and BL03's upper mids and above into a single IEM. As I mentioned when I tried the BL03 for the first time, the sheer presence of the lower mids (200Hz to 1kHz give or take) was eye opening to me, since they range from recessed to nearly completely drowned on every headgear I ever tried prior to the BL03. So what would happen if someone did this? Would it be considered too boring? Too neutral?
True but but people are not brave
I have two pairs of the 03 and one pair of the 05 that I listen to regularly and have experienced zero driver flex on any of them.How’s the driver flex with the BL05 compared to the BL03?
@Slater, would you be willing to put a link to your famous BL03 mesh mod on your signature?
