Does anyone wear them drop down? Seems to be more comfortable for my small ears
Hey I had this problem too, wearing it drop down kinda solves the issue for me. Jaw movement no longer makes it fall out, it was annoying when it falls out a bit everytime I laughIf it fits you just fine then by all means. For me, even using it over the ear, if I yawn, sometimes the right side lose the seal and I have to adjust it again.
Problem is, I am pairing it with bt20s.
How do you spot a genuine or a fake? Mine SOUND like they are genuine (I prefer mine to my MH755) but I don't know for sure...
The genuine MH750 are built exactly the same as the genuine MH755:
1. All black nylon mesh nozzle filter. The fakes have white filters (that may or may not contain a small hole pierced in the center in an effort to artificially improve the treble clarity).
2. Genuines always have a 90-degree 3.5mm end. Some of the fakes have a straight 3.5mm end, but a lot have a 90-degree 3.5mm end. So a 90-degree 3.5mm end alone isn’t a guarantee of a genuine, but a straight 3.5mm end is a 100% guarantee of a fake.
3. Yellowish/off-whitish tuning foam in the nozzle. The fakes have no tuning foam in the nozzle, but some have black tuning foam in the nozzle. So like the cable, tuning foam in the nozzle alone isn’t a guarantee of a genuine, but no tuning foam in the nozzle is a 100% guarantee of a fake.
4. The genuine driver itself has 2 silver ‘dots’ on the back of the circuit board. The fake drivers have no dots at all.
5. The genuine driver is held/sealed into the shell by a circular ring foam seal. The fakes have no foam ring, and are almost always rattling around loose in the shell (ie not held in by anything).
6. Always ignore any labels on the baggies (with manufacturing dates etc) or tags on the cable. The fakes have copied this, so it is a totally unreliable way to tell if it’s genuine or fake.
7. With regards to the black color, the included genuine tips are translucent black (ie smoke black), and the silicone is high quality. The tips included with the fakes are solid black (not translucent), and the silicone is of a lower quality when directly compared side by side.
8. The genuine includes a shirt clip with the eartips. Some of the fakes include a shirt clip, and some of the fakes don’t. So just like #2 and #3 above, the inclusion of a shirt clip alone doesn’t guarantee a genuine, but no shirt clip included is a guarantee of a fake.
So in which case we can add - Sounding good isn't necessarily proof of a genuine MH750. I've a genuine 755 and a fake 750 (no solder dots on mine and short tuning paper although everything else is correct for a genuine one) and the 750 sounds pretty good. Not quite so good as the 755 as it is a bit heavier in the bass but definitely fine for the money. Thanks for the info.
are the backs of the IEMs (where the Sony logo is) the same size as the MH755? That could be another point to note as mine are slightly (about 1 or 2 mm) bigger? Another point I note is that the hole between the two halves of the shell is bigger on the genuine 755 than the fake 750.
Why is so expensive? because it sound good
That’s still ok. BT20 can be worn up or down:
I forget what HeadFier originally shared the idea of wearing the BT20 down, but it’s genius (and it actually works)
hmmm... that ear looks familiar... (looking at the mirror)
