Originally Posted by Hirsch
For the coupling caps, IIRC it's about 0.47 uf at above 400v. At the outputs, capacitor coupling is about 400 or so uf (also high voltage, but I forget exactly how much).
Black Gates at the outputs are terrible. It's not a question of tone, there was some serious distortion at lower volume levels than with other caps, even after burn-in. it's possible that it's the configuration I used (two section cap with the sections paralleled to get to correct uf for each channel). I tried them in one amp, and later pulled them for something that would hold together at higher volumes (eventually settled on NOS Spragues).
I interpreted your statement 'Black Gates at the outputs are terrible' as 'they are not appropriate/terrible in coupling positions in the signalpath'.
Well, when I am wrong I hope you will reply.
If I am right, what other higher voltage coupling caps (160V or higher) that are in the signalpath in tubeamps are in your or others view advisable?
That is interesting because BG's - as usual - brings confusing and various comment with them. Not everyone that has used them in reality is always enthousiastic about their sonic behaviour in coupling positions.
It is not an interesting path in going to use BG's (at their extreme costs!) and than expierence a long waiting time for any sonic quality, irrespective of setting of the volume knob. A couplingcap should in my opinion let through all the relevant music at any volume setting. Otherwise there is something missing in the overall component blending or with the specific couplingcap in the signal path.
I for myself are still searching for an alternative couplingcap in a Antique Sound Lab MkIII (in OTL form). Now there is a rather common cap in the signal path whith no special quality (not bad, do not misunderstand me, but within the price range it is acceptable, but it must be possible to do it better, at some cost.) That means a quality cap of at least 100 mf at 160v or higher. The possible (non polar) Bg's are really expensive and only in non polar form obtainable. Other choices are Panasonic or Nichicon low impedance/long live (but regretteble not at the Pan FM specs!).
After much searching on headfi and elsewhere I have still not found a cost effective choice that respects sonic requirements of better quality than the standard couplingcap. For me it looks like the BG's (I have not yet tried them out in my asl amp!) are not yet my 'cup of tea', especially caused by their costs and requirements for severly burn in and later for 'fire up-time' when not permanently coupled to supply voltage.
