Please cite a double blind test where someone was able to discern a difference between PCM and DSD. I don't believe it.
As I said, I will post the samples of recordings. Then you and everybody else can decide first hand. Let's say the samples will be posted by 15th August, possibly sooner. Should be enough participants to satisfy any statistical requirements. If you are willing, I can let you, as the most prominent opposition, process all the incoming results via PMs. The condition for the participants to be able to participate will be a simple one: confirmed native DSD playback capability. We could add level matching to within less than 0.1 dB - but that is harder to do for the participants and yet harder for us to confirm the precision of their level matching .
What can you say regarding the above offer ?
You can go to any of the following links with free samples in various PCM, DXD and DSD resolutions and also listen/compare for yourself. However, as noted many times before, only native DSD playback will reveal the true difference. You will need another
honorable person to help you with switching for DBT - foobar2000 (or anything else known to me for PC ) at the present can not
play native DSD under ABX comparator. Things are developing in digital audio so fast at the moment that software will eventually have to catch up with the latest hardware. For example, mac enviroment at present does not allow DSD256 ( limited to DSD128 ) - PC/windows does. Foobar2000 even has provision for setting the DSD rate up to - DSD512 ( 8 times the resolution of SACD ).
http://www.2l.no/hires/
http://www.channelclassics.com/try-it-now
https://justlisten.nativedsd.com/albums/just-listen-1-compilation
http://audiogate.bluecoastrecords.com/
http://www.highdeftapetransfers.com/
etc etc
The problem at the moment is relatively very few users have native DSD playback capability. As any novelty, it is expensive at first - and as always, there will be fishing in murky waters. But that is changing - FAST. I do not want to come off as a fanboy of any manufacturer - but check for yourself what 189 $/EUR ( lucky Americans... ) can buy you today in DACs. Your last name no longer has to start with
G- and end with -
ates for you to be able to afford a very high quality piece of digital audio equipment.
Many have ( myself NOT included ) more money in a single cable connection...
