Golfnutz
- Dec 13, 2010
I did not tried one at a time. Sorry.
Right, but those results are just above minimum acceptable values (21-50 mA and >4000 Gm).
Not sure I would purchase anything with values less than 30.00 mA and less than 6000 Gm. Based on the NOS tubes I have and the test results with the same tester.
At least they are matched fairly well, but I would still do another series of tests one tube at a time to see if the numbers are better.
Edit: Try testing some other EL34 tubes to get an idea of how they measure. Maybe your results are normal to be this low (again, with this tester, I would do them one at a time - you don't get true 400v with all 4 tubes in at the same time). Part of the reason to purchase a tube tester is to see if you're getting healthy tubes from a seller.
