GoSUV
- Oct 10, 2011
According to some official pictures (albeit pre-production ones) I have seen, are you sure about this extra cable that plugs into the bottom of the BT transmitter that turns the headphones into wired mode, rather than having to swap out the cables entirely at the MMCX connectors? It looks to me like they are including this wired remote cable with MMCX connectors in the Xelento wireless package rather than a 3.5mm male to 3.5mm male extension cable that you can plug into the bottom of the BT unit. But I could be wrong since the photos could be from pre-production or very early in the design - the announcement from Xelento wireless to actual production has lapsed for more than a year.
If you ask me, I prefer the extension cable approach that you can plug into the bottom of the BT unit for convenience, but from a puriest's point of view, or if the majority of the time I am going to use it in wired mode and only use the BT unit occasionally for wire-free convenience, I'd rather swap out the entire cable (sans remote) at the MMCX connector so the BT unit is not in the signal path at all.
