Beyerdynamic Xelento!
Jan 13, 2018 at 6:02 AM Post #736 of 3,065
Thank you for the feedback, @HarlanDraka81, @money4me247, @Edric Li and @csglinux. Hmmm... Really hard to decide. I sold my Noble Katana a while ago, and I must say although I very much liked its clarity, I was not very impressed while listening to bass (double or electric) instruments. The sound stage was above the average. I listen to my wife's HD800 from time to time (which she uses for mixing) but the highs are too sharp for me to listen to for long durations. I was also thinking about the LCDi4, but it is not suitable for office listening, as I understand, because of its semi-open nature.
I really need to find a way to listen to PP8 and KSE1500 before making a decision. I will start with the measurents, now. :)
Cheers
Jan 13, 2018 at 7:13 AM Post #737 of 3,065
Hello mate @Dobrescu George. After thinking and reading a lot of reviews I placed my bet on xelento. You were so right about my craving for treble. I got my xelento 7 days ago. I was stunned by their gloss. Comfort and seal are fabulous almost like nothing in my ears. Sound of xelento made me go wow. Resolution and details are at finest level. I can feel Bass presence and rumble. I never heard Bass this big. Brightness of treble is very good but not like my ie800. But over all a very well noticeable upgrade over ie800.
Today again I read your review for Ibasso dx200 for 3rd time indeed a very well written review. I was all prepared to purchase Ibasso dx200 and pair with xelento but bad luck not available in my country. I will have to wait more to get prepared for custom charges.
Any ways thanks a lot for your inputs mate.
Jan 13, 2018 at 9:08 AM Post #738 of 3,065
Woah, really glad to have helped!
Thank you for your kind words!
For DX200, please factor in an AMP5 module, it makes DX200 truly shine! I am yet to properly write about the amp modules, but will get to it soon!
Sorry to hear that it isn't available in your country, but I hope that Paul from iBasso can help you receive your order safely!
Jan 24, 2018 at 11:50 AM Post #739 of 3,065
So I had a new experience with my Xelentos last night... the left side was noticeably quieter than the right, and then I started fiddling with it, and the sound died out almost entirely. I looked carefully at the headphone, and I did a bunch of playing with the cable, connector, etc. Nothing seemed to fix it. Tried cleaning the grate, and some material came off, but the sound wasn’t fixed. So I pulled out my Xelento box, and checked the manual and other contents. Hadn’t noticed the little bag of “replacement protective grids” before, but figured that I should try replacing the left grid before sending the headphones back to Beyerdynamic on an RMA.
Thus ensued one of the most frustrating 45 minute struggles of the past year. Good lord, putting a new grid in is a pain in the arse. As it turns out, that did fix the problem, but I ended up crushing one of the grids in the process, and the one that did go in took bloody forever and a lot of very fine (and very firm) manipulation to get it to go. There has got to be a better way.
Has anyone else had to do this yet? Also, is there a way to get replacement replacement grids?
Jan 24, 2018 at 12:07 PM Post #740 of 3,065
I\'m fairly sure you can get replacement grids from Beyerdynamic directly.
As for your issue, the basic explanation is that the grid filled with debris and wax, so it couldn't let sound pass through anymore.
I had this happen only once, with Sennheiser ie80, after around 4 years of usage. When I called the Sennheiser Service Romania they adviced me to use a toothbrush and that fixed the issue.
So, you could also brush the metal grill and you should fix them.
Jan 24, 2018 at 12:23 PM Post #741 of 3,065
I've had my Xelento for over a year, it's the first generation one, the first one I received had a defective MMCX socket, and after a few months, they replaced it with a new pair, nothing has been wrong with the second pair, just that the MMCX connector (cable side) is the main problem with all Xelento, they tend to be rather loose, I use a third party MMCX cable, a good tight fit, but nothing like the problem as you both has mentioned.
All parts can be purchased direct from BD or a authorised agent in your country if there is one, it requires you to send a email to BD, they will either deal with you directly, or direct you to local agent if one is available. Price is rather expensive.
Just to give you an idea, the stock 3.5mm cables is sold USD99-USD125, although I paid USD 48 as BD's agent in my country got the price wrong.
Jan 24, 2018 at 12:25 PM Post #742 of 3,065
I did try brushing it, but that didn’t fix the problem. Either I have stubborn ear detritus or the mesh is too fine for my brush to affect.
Jan 27, 2018 at 6:24 AM Post #743 of 3,065
I hear people saying the soundstage of the xelento is noticeably larger than the akt8ie. I have an Andromeda and owned an AKT8ie. I found their soundstages to be worlds apart.
Did Xelento improve that much to be comparable to andromeda in this regard?
Jan 27, 2018 at 10:17 PM Post #746 of 3,065
If added treble means larger soundstage (which makes a lot of sense for a wide range of genres) to you, then yes, Xelento has more treble than t8ie, thus larger soundstage. However you may be better off with something even more treble heavy if you are going down this path, for example the Ocharaku Flat-4 KAEDE, the Hidition NT-6 pro, or the UM Mentor. Heck, even the K3003 meets your need better than Andromeda.
Jan 28, 2018 at 12:28 PM Post #747 of 3,065
Andromedas treble is almost borderline too much, but is still kinda smooth with everything I throw at it. I've heard james444 saying that too in his review about the Xelento.
Would you say the xelento is as bright or brighter than Andromeda?
I think Xelentos soundstage should satisfy me if it's even bigger than Laylas.
Jan 28, 2018 at 12:37 PM Post #749 of 3,065
It is very emphasized, but still very smooth.
For example the Shure SE846 with white filters has far less extension in the treble, but is sibilant as hell. The Andromeda manages to have an airy sound with lots of treble without sounding harsh or any sibilance. It is pure magic and I've heard a lot of treble inears. Would you say the xelento manages to do the same?
Jan 28, 2018 at 1:09 PM Post #750 of 3,065
I think that Beyer Xelento sounds quite airy, but stays quite smooth as well
Since I don't have Andromeda or SE846, I cannot relate it to either...
