Beyerdynamic Xelento!
Mar 11, 2019 at 11:19 AM Post #1,486 of 3,065
Mar 11, 2019 at 7:31 PM Post #1,487 of 3,065
so fellow Xelento owners... Whats your Tips of choice?
I haven't found a good fit yet, and I own all the popular eartips (just about every SpitFit model, two models of Symbio, several sizes of JVC SpiralDots, Final Audio, etc). For all my other IEMs, the medium sizes of the various eartips listed work very well, but the Xelento have a much shallower insertion so these eartips either don't provide a good seal or they gradually lose the seal.
I'll have to try the stock tips in various sizes again to try to find one that fits well.
Mar 11, 2019 at 9:08 PM Post #1,488 of 3,065
I notice the 'fit' issues as well; when I pull the IEM's out a little, I get better sound? Maybe deep insertion isn't the best?
Mar 11, 2019 at 9:47 PM Post #1,490 of 3,065
Mar 13, 2019 at 3:35 AM Post #1,493 of 3,065
Can anyone tell me how the Xelento's frequency repsonse behaves with a higher output impedance source? I am debating a Topping A30 amp (not solely for the Xelentos), but it has an output impedance of 10 Ohms or even 30 Ohms on its to headphone ports.
Mar 13, 2019 at 10:26 AM Post #1,494 of 3,065
The Xelento's impedance curve is basically flat, so you aren't going to shift the FR with a higher output impedance from your source :-)
Mar 13, 2019 at 4:33 PM Post #1,496 of 3,065
What are the stock silicone tips on the Xelento like, actually? I've heard recommendations for these from several others, but have always been worried about the fit, and I generally haven't had much luck with tip-rolling in the past so bad tips would stop me from getting these.
Mar 13, 2019 at 5:25 PM Post #1,497 of 3,065
I don't like the silicones that came with the Xelentos but I like using the symbio peeled and the silicones that came with my Andromedes. The default silicone dont seal well for me.
Mar 13, 2019 at 5:32 PM Post #1,498 of 3,065
Interesting, guess I'll have to prepare for tip-rolling if I ever try these. Do you prefer the Symbio peeled or Andromeda silicones, though? I have some Campfire stock tips that I could bring to any demos, would be neat if they work really well on Xelento.
Mar 13, 2019 at 5:53 PM Post #1,499 of 3,065
Honestly, I have experimented a lot with tip rolling, and I do not think any one is 'better'; they just have different sound signatures. I can easily go 1 week with Comply Ts-500, then get tired of the sound and put on the silicone instead (not sure of the brand, Andros came with 2 types of silicone), and listen to those for a week or 2, then go to Delkoni bullets, or marshmallows...
Mar 13, 2019 at 7:41 PM Post #1,500 of 3,065
I just took off the comply and put on the symbio peeled, and there is more bass and slam with silicone! Now I put on the Andro silicone (the one without the light-grey center) and the treble and mids are more emphasized...Now i put in the silicones with the grey center, and they have a mix of bass and good treble, but a little closed in-less soundstage, but more intimate, slamming sound... See, for me there is no better or worse, they are just different...
