Solderdude (Frans) findings are accurate, in my experience. He wrote "The fleece disc is very effective above 10kHz but less effective as the frequencies get lower. To get the 8kHz lower and not lower the higher frequencies too much, EQ, or a passive filter are the only options."
I have the original DT1990 and I've tried the Amiron home fleece disc (same as the TYGR one): It goes in the right direction, but, as Frans graphs on bot MKI and MKII show, they do not lower the 8k peak entirely: It is better, but still annoying. If you go on and stuff other things in front of the driver (foam, felt, toilet paper etc.) the 8k peak is furtherly lowered but every other frequency above is lowered too, so that you end up with a muffled high region very soon.
From his graph you can easily deduce that the fleece disk on the MKII has a very similar effect to the Amiron home/TYGER one: It goes in the right direction but it is not enough, and the peak is always there.
My ideal solution is.... Solderdude filter: It targets the 8k peak with a much heavier reduction than the Amiron fleece disc, and leaves most of the higher frequencies response unaltered (or very subtly lowered). After I got his filter I do not use the Amiron fleece disc anymore on my MKI.
In case someone is interested and is from europe I can sell for cheap one of my filters for the MKI (I have two of them). Or, of course, Frans can do filters for both the MK1 and the MK2.
