Chastity
- Aug 24, 2002
I've never disassembled my headset, sorry.Anyone, please?
It's a very specific question on an headphone that can't be run balanced so it's going to be difficult to find someone that's had the same issue. On the other hand a scratch doesn't affect the sound, maybe it's time to confront your OCD?Anyone, please?
Yes having owned and used the 1770 Pro and still have my 1990 Pro, if you're looking for isolation then the 1770 pro are sufficient enough.Could someone explain to me the differences between the 1770 Pro and the 1990 Pro for mixing, mastering or tracking? I like to have a single headphone that could do all, but the thing is that I like the isolation the 1770 pro provides since there is always background noise where I live. Is the 1770 pro sufficient for all sorts of audio engineer works when i can't use my studio monitors?
Just got my elite Velour pads and my first impressions are positive. I was surprised how much thicker they are then analytical pads - see picture. I had no issues installing them in the "groove" once I figured out a trick - spread your finders on the inside of the pad so it keeps most of it's circular shape, and twist your hand.
Still need to listen for a while to see how they sound, but they are comfortable on my rather large/awkward earsThey feel a tad warmer than the A pads - but they are also sitting in the mailbox in the Florida sun
Can any of you guys please post a link for these pads?
Care to share the $10 coupon code? @DekoniAudioNot enough use yet to comment on sound stage. Btw I pmed the dekoni rep and he sent me a $10 off code.
I think it was tendollarsoff - don't know if it's one time use.Care to share the $10 coupon code? @DekoniAudio
Code works, I ordered a set for myself.I think it was tendollarsoff - don't know if it's one time use.
I don't know if it's my SBX AE-5 soundcard or the headphone itself but i feel like mids are a bit forward than i like with the DT 1990. It balances out itself at higher volumes though. It's really euphoric experience but forward mids/vocals giving me fatigue. Coming from DT 770 250ohm their mids are laidback and much more easier to listen. Even though DT 770 is harder to drive i have no problem with it. DT 1990 is easier but i feel like higher volumes makes it more even/balanced, detailed, clean, textured and opened up soundstage. Low volume: mids are overpowered for my taste.
I've ordered dekoni elite velour as well. I'm liking both balanced and analytical pads but balanced pads giving more joy/euphoric experience while analytical pads giving more smooth/calm/detailed sound but less spice.
I don't have any problem with treble peak. I don't hear any sibilance. I've tried Sonarworks and oratory1990 eq but imo they are bad.
