cardeli22
- Nov 7, 2014
Maybe I missed it in this thread but I couldn't find it in a google search, Can anyone recommend a good tube amp that pairs well with the 1990s?
I use my 1990's with a Darkvoice 336se and a Feliks Elise, both pair very well with the 1990.Maybe I missed it in this thread but I couldn't find it in a google search, Can anyone recommend a good tube amp that pairs well with the 1990s?
The sexiness of the Elise. A fella can dream. lolI use my 1990's with a Darkvoice 336se and a Feliks Elise, both pair very well with the 1990.
Nice. Yeah I have been looking at the sale forums more and more. Really like the design of the bigger tubes on the darkvoice and the Elise.Lol, well I was dreaming too until 2 months ago, I managed to pick up a mint 1 year old example example for less than half price, so you never know!, anyway what about the Darkvoice?, that is a very good amp for a fraction of the Elise, also it will drive the 1990's with ease, I rarely go past the 9 o'clock position with my DV.
They can get quite hot depending on what tubes you're using, the 6080 type power tube (straight sided and smaller than the 6AS7G) runs hotter than the 6AS7G type, (most of the heat comes from the power tube at the back), also using a socket saver helps to cool it down a bit, but I have never had any problems with mine. Here is a link to the Darkvoice tube rolling thread, if you are interested this should give you all the info you will need on the DV.So how safe is the darkvoice? I saw a thread on another site about how you may need to store a fire extinguisher near it at all times.
Awesome, thanks.They can get quite hot depending on what tubes you're using, the 6080 type power tube (straight sided and smaller than the 6AS7G) runs hotter than the 6AS7G type, (most of the heat comes from the power tube at the back), also using a socket saver helps to cool it down a bit, but I have never had any problems with mine. Here is a link to the Darkvoice tube rolling thread, if you are interested this should give you all the info you will need on the DV.
https://head-fi.org/threads/darkvoice-336i-336se-tuberolling-partii.348833/
Hello
Im new to this forum but i have been checking out this topic for a while.
I just bought myself a pair of these (DT 1990 pro) and i have a question about dac\amp.
Now i have a NAD D1050 and the sound was a big upgrade from my (DT 770 Pros).
The question is do i need a headphone amp while im using the NAD just as a DAC ?
And if so which amp ? With Tubes ?
