RockStar2005
I think the 1770’s are absolutely superb. When you need closed-backed headphones, with a neutral signature, there are no better IMO.
I like your post ALMOST as much as I like your avatar. lol
Will the Schiit Magni 3 with it's .43 watts and 11.36 volts at 300 ohms per channel be enough to make the 1770 shine? I recall a few pages back someone mentioning that it really needs the more than double the output as found with the Lyr 2.
How comfortable are the pads on the 1770 ?
Hello guys, I'm buying the DT1770 pro 250 Ohm to mate with the LG V30. Can I please ask a few questions, I've been a member here for a long long time and its been ages since I bought something new.
1. Can you recommend a cable upgrade to stock cables?
2. Do they require a burn in period or do they sparkle out of the box? If so, how long? What burn in applications do you recommend?
3. Any recommendations for pad upgrades too?
Thank you so much. I'm very glad to be back on the scene in 2018.
Hi I am using DT 1770 PRO for 3 years and I love it.
I use ORB Clear force and FURUTECH iHP-35X II. Clear force is a better cable for me.
It took me about 50 hours to burn in, but 1770 sounded good from the time I opened the box.
Thank you for the reply friend, can I ask where you got the Orb Clear Force from? I'm having some difficulty in finding it, seems like a Japanese Domestic Market model? Sounds great, I'll be happy to purchase this cable and get back to the group with my impressions over stock cable after burn in.
It's got the power, but it doesn't really bring out it's full potential. The best pairing I have found, is the Valhalla 2.Will the Schiit Magni 3 with it's .43 watts and 11.36 volts at 300 ohms per channel be enough to make the 1770 shine? I recall a few pages back someone mentioning that it really needs the more than double the output as found with the Lyr 2.
