I prefer the Comply tips, and I believe that the Ts-500, T-500 and the TX-500 will do you fine, and all come in three sizes, Small, Medium and Large. The difference between the Ts-500, T-500 and the TX-500 tips are that the TX version has an integrated wax guard and is ultra soft, which I really wanted on my (now soon to arrive) replacement Triple.Fi 10's; the T-500 is cheaper without the wax guard, and the Ts-500 uses a spherical shape. Check the
website for more info.
However, I am highly interested in getting some custom ear mould sleeves (tips). I wrote this on some other posts, but this is what I am considering (taken from this
post):
"ACS Communications Solutions (alternate site) are pretty famous in the UK for making ear moulds for Etymotic, but they do make ear moulds for other earphones (ACS UK Custom Fit Earphone Sleeves). I have three places where I can get this (HiFiHeadphones.co.uk, iHeadphones.co.uk, or BootsHearingCare.com), so there is no rush and I can mull over which would give me the best to purchase from."
Once I have bought a suitable headphone amplifier*, an LOD (
Moon-Audio.com’s Silver Dragon V1 LOD Cable or Silver Dragon V3 LOD Cable), and possibly an aftermarket cable (
FiiO RC-UE1 Replacement Cable for Ultimate Ears IEM’s), I shall see if I should (or even can) get the sleeve's.
*I am currently in talks with John Seaber from JDSLabs.com about his C421 amplifier, though his cMoyBB amps are very popular and great to use. I still use my Custom cMoyBB v2.02, which are highly enjoyable to use.
Otherwise, the Comply foam tips will do you for a while, but remember that they are the more expensive option in the long run. If you really don't like foam tips, and the silicone UE tips don't work (they do
NOT work in my ears, far to much discomfort), then your only choices are to get modified, DIY hacks on other tips from other brands, or get custom moulded sleeves.
