regal
- May 27, 2006
Still a 2 channel amp, with a transformer/phase splitting, no advantage of balanced vs unbalanced inputs. Signal is combined at the driver stage and split again at the output transformer. Probably 3rd harmonic dominant. Why compare this to an SET amp, thats apples and oranges?
Originally Posted by Parafeed /img/forum/go_quote.gif I'll preface by saying that I'm not trying to be argumentative, but how many balanced headphone circuits have you built and listened to? (Balanced == differential, not balanced == bridged.) Without getting bogged down into what sounds good on paper - perfect AC balance from a LTP, K&K's differential headphone amp design, (the circuit used for the Moon Audio amp if I remember correctly), is a good starting point. (I've built this with paralleled 6H30 output tubes as well.) In terms of dynamics, this will leave the 6EW7 direct coupled amp you proposed building in the other thread, crying in a corner. |
