Parafeed
- Jun 6, 2005
I've been fiddling around with drivers in front of the cathode follower.... 6H30, 6SN7, C3g (triode strapped), 5965..... But I found some ECC88's that I had forgotten about, Siemens CCa's and Amperex, so that's where I'm at right now. My EL34 CF is CCS'd too.
Both. OTL - I've been listening to 600R T1's coupled to the cathode of the EL34 using 100uF poly Obligattos. That's what I'm listening to right now. Transformer - I've had a pair of TL-404's hooked up, but I've not spent much time listening to that config. The T1's through those Obligatto caps sound very good.
Originally Posted by nikongod /img/forum/go_quote.gif My amp is a CCS'd 6sn7 into 5998/6as7 cathode follower with cathode CCS. |
Originally Posted by nikongod /img/forum/go_quote.gif Do you transformer couple the output or run OTL? I have mine set up to run both ways for different headphones and single driver speakers |
