salla45
- Mar 12, 2014
I'm running Adam A5's off Mojo as a desktop setup.
Sounds really musical to me! I've had the Adam's for 6 years and still going strong.
I've not done in-depth analysis/comparisons with my other DAC's but I'm now only using the Mojo to feed them running Spotify (with Equalify Pro so I can send ASIO/Wasapi signal direct to Mojo) and it does the job for me.
I can't recommend Adam A5 speakers enough (and the A7X are even more amazing). They're analytical, yes, but they also really pull you into the music. They still leave me in awe even after 6 years. The transparency, airiness, accuracy is just amazing.
I wouldn't recommend them for non-nearfield listening though as you lose a lot of the magic if the positioning is not optimal. For a lounge type setup I would go for something less directional.
thanks for this. The nearfield/midfield "sweet-spot" issue is certainly something to consider with the Adams. I'm still prevaricating over getting the A7X's
