dhruvmeena96
New Bee tips.....no complyHello friends, I am with the ZhiYin Z5000 and the comply foam that come as standard. Do you know what model to comply with is to ask for a replacement? ... thanks
It is not about burning like in old days......but is about making some coil to magnet interaction movement calibration.....
Burn used to happen in old days when due to movement, heat was produced, wreaking the magnet and expanding the diaphgram, making sound smoother. .
But my technique is to physically push diaphragm on constant load to achieve a very specific strength....sheer strength of diaphragm, at that specific point, it would be weaker than initial diaphragm and would be easy to move, hence averaging any disjoint decay.
BA ages... Chinese settle quickly than Knowles and sonion, and white noise does it quicker
Alright guys, can anyone recommend a good Aliexpress in ear wireless sports headphone? Loads on the site but who knows what they sound like...
Also alot of in ears on this thread..apart from bosshifi...what are the top over ear cans?
Whenever I see this type of question I always jump in with pointing out that there's another Bluetooth option that may work depending on your situation. An inexpensive, ie < $15, Bluetooth receiver. You just plug whatever wired headset you want into that. Has the advantage of @Slater 's suggestion in that you can choose the IEM you like. Disadvantage that you've got the cable although the receiver is small enough one of those arm band type holders could be used and it could wrangle the extra cord too.Alright guys, can anyone recommend a good Aliexpress in ear wireless sports headphone? Loads on the site but who knows what they sound like...
