Slater
Need some advice guys... The cable on my beloved T2's has broken and needing a replacement, any suggestions and will any of the MMCX cables from NiceHCK fit?
KZ sells some upgrade cables with MMCX connectors. I’ve had good luck with them.
If you’re going to buy one of the upgrade cables that are $15-$20something, you may as well get another set of Tin Audio T2 as they’re on sale for $30. Then you’d have the cable and a 2nd set of earphones.
