Slater
Hello guys, long time reader but posting for the first time.
I was wondering if I can get some recommendations for IEMs which I can wear under a full face motorcycle helmet. I have Qcy q19( slim Bluetooth ones) Mpow (again Bluetooth) and both comes off when I'm trying helmet on and extremely painful duel to the size of them.
Budget is under $50 and after something which will provide excellent isolation as wind noise reaches over 90 db on highways which extremely dangerous.
I was scrolling through the forums and was suggested cx300 as a good suggestion given the size and isolation it provides and shure ones which are out of budget for.
In terms of C-HIFI, I do like the KZ Zs5(similar to shure ones?) I would prefer Bluetooth ones but wired is fine due to smaller size and comfort.
Thanks in advance
QKZ DM300. It's wired, is behind the ear design, and has removable cables. It's sealed and it has excellent isolation. The shape allows it to sit very flat in the ear, and it results in a secure and comfortable fit. It will be smooth to take your helmet on and off with the DM300 inserted.
The sound is v-shaped (single dynamic driver), and decent for it's price. You can read about it here: http://www.aproear.co.uk/qkz-dm300/
2 others with similar design, fitment, isolation, and sound characteristics would be the QKZ W1 Pro (wired, behind the ear, and the sibling to the DM300) and the iRock A8 (wired, behind the ear, and a 2x dynamic driver).
The iRock has a slight mid-forward sound, which some people like and some don't. It responds to EQ very well, and once tailored with EQ is definitely the best out of the bunch. If you don't want to EQ and just want to stick with the stock sound, I would go with the DM300.
Those would be my 3 recommendations based on your requirements. All 3 are easy to drive with any source (including cell phones). None are going to sound as good as the ZS5 though. What's really holding you back is the helmet requirement.
You MIGHT also be able to get away with the MEMT X5. It's physically very small, but it is not flat like the others. So I can't guarantee that it won't rub or get tugged when you take your helmet on and off.
