bluedolphin
- Feb 27, 2011
Since Forever i always had problem with one side of the head or earphone stopping working
because the soldering of the cable to the headphones get loose
This happens mostly after 6-7 months of use, the longest they lasted with everyday use is 2 year (Sony)
I'm 35 years old and since in the 80s i got my first Walkman i have been using different brands since then.
In the 80-90s I used a lot of Sonys and Aiwas and some Philips and Panasonic
I went over to better sounding headphones such as Audio technica,Koss and Sennheiser
The best sounding bassy headphone i used outdoor was some big Aiwas and Koss KSC-35
I have used few earbuds as i not find them comfortable because of a health condition also i have to clean them more often
and most of them (low range) just popped out of my ears (only one that was comfortable was apple ones but they sounded bad)
I used all kind of headphones system over ear, clip-on, earbuds etc...
even those popular earbud with headbands back in the 90s
All had the same problems wire soldering loosing breaking down in 6-7 months and music only then come from one side.
Sony for some reason has a more solid cable and did better than other lasting up to 2 months but usualy 12-15 months
(exception is studio headphones in door use that last longer because i dont move them so much or the cable is so fat)
I am so fed up of having to buy new headphones because of the Wire soldering i try to find a permanent fix
So Can you recomend me a Good Headphone with Detachable cable that is not too big to wear on the street
sound good and is not extremely expensive.
I be willing to check out audiophile earplug too just keep in my i find plugs extremely unpleasant and i dont like anything inside my ears, Also i have to clean my ears more often as they produce much more vax (health condition i had since child) than normal so i think i be better of either with some Headphones or some earphones that are easy to clean
As Audiophile headphones goes i cant try them in local store here dont have them so i have to rely on reviews and opinions.
But what i need is something that sound good with Pop and a little Bassy without distortion
(somewhat like Koss Ksc-35 or better)
I dont feel like using the Koss lifetime warranty all the time cause then i have to use it every 4-5 months the headphone problem happen.
So please anyone that has detachable cable and one that is easy to buy extra cables
so i can stock up on some cables and just Easy unplug the cable from the ear or headphone when they break
Suggestion?
Suggestion?
