wolfetan44
- Mar 27, 2012
So just as I was about to order the Kef iQ30's, they have been discontinued. So now where should I look for my speakers?
They show in stock for me:
http://www.kefdirect.com/iq30-bookshelf-loudspeaker.html
Dang, just figured out my receiver does not have a phono stage.. Any recommendations for $150, since I'm saving money on the speakers?
Isn't that builder/site, it's something like "phonostage.com" still in existence? I'd jump on Amazon and just look for "phono preamp" or "RIAA preamp" - I know there are plenty of inexpensive (like $50-$75) options out there.
This looks like what I'm remembering:
http://www.amazon.com/TC-750-BLACK-Audiophile-Phono-Preamplifier/dp/B000A36LQ4/ref=sr_1_6?ie=UTF8&qid=1352975861&sr=8-6&keywords=phono+preamp
Have you seen the Emotiva mini-x a-100? Seems like you could plug that into the lineout on the Lyr, and then use it to power passives.
In addition to the B&Ws, also check out the Focal Chorus series.
Well, yeah. The Rotel would definitely be a better ampAlthough I think for the price of a Rotel, you'd get more bang for the buck buying a $500 amp and putting the cost of the amp towards speakers.
I don't know why the Lyr has a line out on the back if it's not meant to connect to an amp. What would it be used for otherwise? The question I would be concerned about is whether or it's a straight line output, or if the volume control is affecting it. You might need an integrated amp.
I believe the outputs are volume controlled, so it could be used as a pre-amp. I do not believe that they are run through the full power output stage though (so they are not throwing 6 watts down the line out).
So, why I got this idea in the first place. Well if I get speakers like the B&W 686s that require good amplification, I'd rather go with a power amp, rather than some budget integrated amp (not a huge fan of those). A power amp like the Rotel, is also a nice base for future upgrades with speakers and it could be rather flexible in terms of what pre-amp I can use with it. It would also make excellent use of the Lyr, since it was kind of meant to serve as a pre-amp as well.
The reason I suggested is that I previously owned the 601s, which had a reputation of also being hard to drive, and which did surprisingly well without $1000 of amplification. If you shift your budget to 2/3 for speakers, and 1/3 for power, that puts you in the range of the CM1s, which are considered by almost all B&W fans to be a better class of speaker than the 600 series. Which by the way, have a minimum impedance rating of 5.1 ohms (vs 3.1 ohms for the 686), making them even easier to drive. But if you've heard both and like the 686 better, than of course personal preference should always trump
