KneelJung wrote:
Question: since the Clip doesnt have a dedicated line out arent you essentially just amping the signal of the headphone out of the clip? What does the amp do other than more volume and IMO the Clip gets plenty loud enough on it's own so I guess I dont really see the point.
Working with you on your question. When I first started out on this sojourn, maybe a day or two ago, I had a similar question. Through much effort on the part of those who frequent the forum, many tried their level headed best to help me see the light. They weren't able to help me see the light but now that I'm older and wiser, I'll try to do the same for you, as yes, I have seen the light and it's a colorful one. But remember, in the end, you're the final arbiter and it's your choice whether to respond to what I'm sharing or not.
The easiest analogy is a car motor's cost and the engines efficiency in pumping air. Do you want an old beater to replace a blown engine, or do you want a screamer to do some drifting in? After all, in the final, they're all just a motor in an engine bay. The amp is the same. The amp doesn't "just" make things louder. Better amps keep frequencies separated while making things louder. With a cheap azzzz amp, you have loud noise. With a quality amp, you have loud music.
Most cheap amps or amps supplied in a DAP, will easily do the mids but you'll have muddied or muffled bass notes and you'll have congested or compressed (clipping) highs as the amp won't have enough torque to get you there, let alone enough horsepower to keep you there. Think dynamic range. Now, think of an engine at max RPM with too little carburetion: choke, choke, choke, choke at fifty-five hundred RPM's. You can have the finest engine design in the world but too small of a carburetor and well, you get the picture. It's the same with an amp. You won't have the dynamic range, even at low listening levels, so your bass notes will load up and become muffled and your highs will become compressed, or clip and make your poor ears bleed, in a bad way.
Personally, I'm looking at a couple of suggested all-in-one DAP's so I won't have to add an additional amp as I too want to keep it simple. So please, don't think that I'm trying to sell amps as what I'm trying to encourage is affordable sound quality and a quality amp, whether in the form of a quality DAP or a separate amp, will help you obtain that goal. And like the best engine in the world and a lousy carburetor, if the amp's not there, then the best earphones in the world are going come out sounding second best or worse. Mid-range pricing for all-in-one DAP's that I'm currently considering:
Cowon J3 or a
Nationite S:Flo2.
Now for the final arbiter part. Some people are happy with simplicity and bloated bass notes accompanied by compressed or clipping high notes. It's free choice and free will when one decides to make the choice regarding keeping a few bucks in their pocket or keep their ears from bleeding all the time. Remember, on this issue, you're the final arbiter of what I wrote in response to the question: quality sound, mediocre sound and how long do you want your ears to bleed for.
Hope I did a decent job in answering your question.
