Best Smartphone for audiophile Part II (Updated: Jan 2020)
Jun 21, 2019 at 9:07 AM Post #2,581 of 5,166
Since you said the same thing happens with the BTR3 connected to the P20 my guess is that something about the EMUI is limiting the “bass boost” you are using.
In any case EQing the BTR3 directly from the fiio app would be a solution since you have direct control over all the frequencies and the EMUI cant do anything about that (since the changes are local in the BTR3 memory)
Tried it, but it doesnt really help. I dont have any local files, I only listen through spotify.
Also coming back to the Pocophone, connecting directly and plus bassboost its a nearly perfect sound.
Using the BTR3 with the Pocophone and the exact same settings: nearly half the bass.
This is sad. Might try the earsonic ES100, atleast that one got a global EQ thrhough the app
Jun 21, 2019 at 9:45 AM Post #2,583 of 5,166
My 1st choice was Xplay6, but the price was double the Meizu...Sadly..
Double meizu pro5 is still cheap. Pro5 is $100 now right?
Jun 22, 2019 at 5:44 AM Post #2,586 of 5,166
Jun 23, 2019 at 6:29 AM Post #2,587 of 5,166
I got ibasso dc01 and now burn-in it for some time now. It has the tonal like fiio m11. Good detail and great instrument precision. The vocal is clear and not interfere with mid bass. Very good implementation.
The only drawback is it causes some.hiss with sensitive iem i.e. andromeda and fitear.
However for dynamic driver earbud, it has no problem. And has enough power to drive no more than 50% of volume scale.
I love dc01 combo with rose mojito.
Jun 23, 2019 at 8:05 AM Post #2,590 of 5,166
Agreed. It has incredible price to performance ratio.
Intrigued by this. Been wanting to get an upgrade in sq without getting a dap or a clunky dac for my portable setup
You won't regret with the DC01!
Jun 23, 2019 at 8:11 AM Post #2,591 of 5,166
Those who have ibasso dc01, recommend this app to control volume. It not only cleans out hiss/noise but also is compatible with all apps with problem that volume is unadjustable.
Jun 23, 2019 at 8:20 AM Post #2,592 of 5,166
Thanks for the recommendation! :)
Jun 24, 2019 at 1:41 AM Post #2,594 of 5,166
SO here's my current situation.. I have three choices to choose from:
1) Vivo XPlay 6
2) Vivo Xplay 5 and
3) Vivo Nex S..
Which one do you think I should go for? I really love music and have a few KZs in my portfolio..
Xplay6 and Nex S are fine. Depend on your budget.
But better get new phone for firmware support and better battery and better camera.
Jun 24, 2019 at 8:56 AM Post #2,595 of 5,166
