4andr
- Feb 24, 2017
Guys, which one would be closer to my reference Questyle QP1R - Granbeat or Vivo x20 plus or Marshal London? Who had them?
Thank you!
Thank you!
I have xplay 6, my friend has x20 plus. Both of us confirm that the audio quality of xplay 6 is superior in all of aspects than x20 plusGuys, which one would be closer to my reference Questyle QP1R - Granbeat or Vivo x20 plus or Marshal London? Who had them?
Thank you!
I would personally go for the LG V20 because of the quad DAC, it can power up all my headphones pretty well. And I like the wide sound stage with the deep bass, depends on what you like to listen to really. I like rock and metal so I would go for LG.So in terms of dac and amp, which is better? Meizu Pro 6 Plus or LG V20?
Appreciate it!
LG V20 for sure.So in terms of dac and amp, which is better? Meizu Pro 6 Plus or LG V20?
Appreciate it!
well I was hoping to also make use of 6.4" screen and a top notch camera (ranked very high at DXOmark). i always have either qp1r with me, for the best possible quality (though, amazingly, amoi c50 is on par!, you should try it guys), so x20 plus could be a very good all rounder. is xplay 6 so much better than x20? )
LG V20 for sure.
xp6 is far better than x20 both in rear camera and music. If x20 get DXOmark at 90. I would give xp6 >95. Bokeh mode is top notch. In term of music, xp6 has more powerful amp and make sound fuller and more details (so if xp6 is 10 x20 is 6.5)
I bought the axon 7 mini from CEX second hand, I am very annoyed though because the NFC was not working. So I had to give it back
Now, I have the option of a few smartphones, the axon 7 is one of them but it's a bit expensive so I think I'll go for the HTC 10. I was so happy with the axon 7 mini overall but be careful to test it for important things like NFC before you get it if you get it second hand.
The Axon 7 is discontinued. According to it's subreddit, quality control and specific hardware issues seem to develop more commonly than more expensive competing brands. To counter this if you're in a region that it sells in, it comes with generous two year accidental damage warranty. Here in Australia it's been on clearance at retailers for a few months. For these reasons I'd recommend getting it new with warranty if it's available. For the same reasons of lasting hardware I wouldn't recommend getting it used or without warranty unless it's a really good price and you're ok with poor quality control.I bought the axon 7 mini from CEX second hand, I am very annoyed though because the NFC was not working. So I had to give it back
The Axon 9 sequel is yet to be revealed.
Do the amps on the V20 and xplay6 put out equal power? Let's assume you want to drive 300ohm headphones which delivers the most power? It's hard to find these stats for smartphones unlike DAP's which list all this stuff!
no that’ll do, anything more powerful than the LG V20 is pretty great for a smartphone in my books. Thank you!From what I have my rough measurement is while v20 gets 2Vrms at max volume, xp6 gets 2.5 Vrms at max volume. (DX200 single end is 3 Vrms)
But I dont have tools to measure power in mW at different loads like manufacturers have.
