Anders
- Apr 22, 2002
Some experiencies and thoughts about HD650 cables:
The stock HD650 cable is quite good, the only problem I had was a slight hardness in the treble. Some others have reported similar impressions. There is not the same need for immediate replacement as with the HD600. You can at least consider to spend the money on a good source or amp first and then upgrade the cable.
In my experience the tonal balance of Zu was close to the stock. It has better resolution and much better bass than the stock but I would not say that the bass is stronger in general. When there is low and strong bass in the recording, Zu lets it through to an amazing extent but it doesn't sound bassy in general. When there is moderate bass levels in the recording, it sounds so.
I don't think Zu has more treble than the stock, in that case only marginally. The treble hardness I heard disappeared and I got a cleaner and more refined treble. Only problem I can have is harshness in bad recordings, but I think this is a problem with recordings because it only happens with recordings that are bad in other aspects also and not on overall good recordings.
Edit: There has been a problem with the Zu plugs but this is fixed.
I have not heard the Russ Andrews cable and it doesn't seem promising. It is substantially more expensive than all other cables and I have not found any reason that it should be that much better. It is made of Kimber PBJ and this has been tested in the PBJ headphone extension cable. What I remember all who have compared, preferred the DiMarzio Big Red or the Hurricane over PBJ.
www.russandrews.com , but not much information on it.
But of course, you can't be shure without testing!
