Zebutsu
- Jul 8, 2012
Hey! How do you get the best of your music? Do you download or just listen to from youtube? Any certain audio file? I currently got the ATH-M50
The actual recording weighs considerably more than which ever file of it you have.
Even though it depends on the uploader they usually(the 1080p ones) hit around 160kbps. I've never had a really good one that matched the 256kbps AAC's I personally encode from the lossless copies.
Talking about Best of Sound, my Linkin Park Living Things album will be here tomorroW! [size=medium]t(-_-t)[/size]
Thanks! I'm really new to this audio world. Thanks for helping out. Do you know about any great sites to download or listen to music from?
https://www.hdtracks.com/
or Pandora, Grooveshark if it is availble in your country, last.fm, etc etc.
Or iTunes or buy the physical album off Amazon. I would avoid Amazon MP3's. Their encoding and tracks that I have downloaded were down right horrible.
That's a very good point, there's a great divide between actual musicians and people with lots of experience and/or training on the matter on what actual instruments and filters should sound like, and those who are just getting into the hobby who think that--because these 'pros' are able to tell the difference on their HD800s, that the lesser experienced would be able to do the same. I remember I took a 320 vs 128kbps test on some site and posted the results. A guy I knew on a site got about the same results that I did just using his laptop speakers, he also plays instruments daily.
