passie42
What tip would temper trebble the most ?
Any ideas?
Any ideas?
Black Final E is one of them at leastWhat tip would temper trebble the most ?
Any ideas?
Ok. Thanks.Black Final E is one of them at least![]()
I stopped using CP145 because W1 gives me a better seal. That's the only difference for meAfter discovering the SpinFit W1 and being very enthusiastic about it, I wanted to know how it differs in sound from the CP145, which has practically the same shape. Does anyone have any experience with them?
Ok. Thanks.
And what do you guys prefer, silicone (Spinfit, Final E, Dunu, Azla xelastec(well not silicone but TPE)) or foam (TRN, Comply) ?
For anyone that has larger outer ear canals and IEM that have short nozzles or for some other reason require a somewhat shallow insertion meaning the tips need to seal in the wider outer part of the ear canals, Penon makes their Liqueur tips in L and XL being 14mm and 15.5mm diameter in black and orange.
I have some of both on order but got an earlier version of the 15.5mm ones in a previous Penon order and they are a life saver on one particular set of IEM on which the more typical 13.5 to 14mm large tips of various brands are just a tiny bit small to provide a good reliable seal that stays put without messing with them from time to time.
https://penonaudio.com/Penon-Liqueur-Silicone-Eartips.html
It never ends does it? Lol. I have way too many tips, and still haven't found the perfect tip yet. Velvets are #1 for my use case now, but I'm still looking.So after some hours with the Divinus velvet tips, here's my verdict:
-Sounds pretty much like the majority of wide bore tips
-Comfortable for long periods (I have no tried to see how long i can hold mind you)
-The stem will hold really tight, specially with iems with lip nozzle
However,
There's a seam line around the outer edge, and somehow these accumulate a lot of ear wax. Even more surprising, these I can't clean by just rubbing them in my fingers, I really have to pull out the rubbing alcohol
so they're alright, but I will keep doing some tip rolling
@BS5711
Those look really tacky, are they a thick silicone or are they on the thinner side? The dome shape is promising, usually means they don't invert on removal. Do they cling to your ear canal and cause any irritation on insertion/removal?
I've had success with the Tangzu Sancai's, narrow and wide bore but tbh I prefer the narrow.Do you guys know of any eartips that help regulate pressure from IEMs without vents? I'm loving my Pula PA02 but after a while they really mess with your ears
